bravo 1 to xr's what is needed to install
The red dot gimbal bearing ( it's thinner, allows
the use of the longer u-joint assy)
They also have trim cylinder spacers to limit
max tilt height, but that wont prevent you from installing
the drive to the bell housing.
Depending on what year transom assembly you have you may need a gimble bearing kit mentioned earlier..
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
