#3's to ????
Old 06-17-2010 | 05:53 PM
Default #3's to ????
I got #3's on the cafe. Lower gears are out on both. So my current thoughts are:
Replace with rebuilt #3s and try to find gear sets for my old ones and to have an extra set on the side. Probably $13,000 to 17,000.
Or: replace with konrads. Probably $20,000 plus props.
Or: Place wet sump #6's on the Cafe. Probably $25,000 to $35,000+ depending on my luck in finding used and transmission cost/modification.
I currently have 600 - 650 hp naturally aspirated. I hope to blower the boat at some point in the future.
What's your guys thoughts?
#6's to much for an old cafe?
Any other options I should be considering?
Any leads on drives or gears?
Chad
RebarBox is offline
Old 06-17-2010 | 06:08 PM
BDiggity's Avatar
Well, if i was spending your money i would go Konrads 1st,
Or BMax's second. JohnP took over the Bravo Shop & plans on getting the drives back out there. He has them on his 46 BT w/ trip 850's. Course would need to do transom work for the BMAx's. Good luck.
Do any Cafe's have 6's?
BDiggity is offline
Old 06-17-2010 | 08:40 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Or you could put Arneson's on it. Boat would run better than the options you have listed and gain speed.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 06-17-2010 | 09:08 PM
HotPursuit's Avatar
I wouldnt even think about it!! Sell are trade whats good and install the 6s and be done with it.If you want to ride more than Idle.
HotPursuit is offline
and that option would run $?????
I wonder how that hull would like Arneson's?
RebarBox is offline
Old 06-18-2010 | 08:39 AM
I have a fresh pair of 1.58 26 spline # 3 also fresh 1.5 same shaft size
rogersspeedshop is offline
Old 06-18-2010 | 11:23 AM
Can you PM me your phone number?
RebarBox is offline
Old 06-18-2010 | 02:19 PM
gary cook's Avatar
Racer
Racer
Default #3 outdrive
i have a fresh #3 and gimbel thats fresh i want 3500.00 for both. left hand. if you are interested give me a call at my shop 586-465-2120.
gary cook is offline
