Need some Torque Specs for TRS >
Old 06-26-2010 | 05:07 AM
Audiofn's Avatar
Charter Member #232
Default Need some Torque Specs for TRS
Hey guys I came up to work on my boat in Maine and forgot my manual for my drives. I need the torque specs for the fallowing
I have to remove the input shaft so I need the specs for the fallowing:
1) The cover bolts at the top of the drive and back cover.
2) The large nut on the back of the input shaft
3) The Tilt Pins for the bell housing
4) Drive to bellhousing bolt.
I think that I have a manual available to me up hear but won't know tell later today so I figured that this could be my back up.
Jon
Put your best foot forward!
Audiofn is offline
Old 06-26-2010 | 06:49 AM
Default TRS Specs
Top and rear cover - 20 ft. lbs.
U-joint shaft nut - 200 ft. lbs.
Hinge pin - 60 ft. lbs.
Drive to bell housing - 80 ft. lbs
RWS Cigarette is offline
Old 06-26-2010 | 07:18 AM
Audiofn's Avatar
Charter Member #232
Thank you very much.
Audiofn is offline
