upgrade or replace B1?
Currently I have a 496 MAG, B1 1.50 and will be installing the Raylar/Dana kit. With all of the threads posted here, I'm pretty confident that the stock B1 won't take the extra power. At least not for very long.
Can I upgrade the stock B1 or should I be looking at another drive to replace it with. Just keep in mind that I just want to go a little faster than I could from the factory (maybe 70-75 tops) and will not be racing this boat offshore.
Advice?
Advice?
Advice?
Advice?
If you deciede to stay with the bravo, I have 2 with 1.36 gear ratios you purchase cheap to have as backups and its rumored the 1.36's do a lil better with the extra power.
hi i wouldnt mind a coulple of spare drives as backup ,have 28ft pantera with twin 496 ho 2001 with B1 1.50 one off the drives got stuck in forward as i was driveing on to trailer not to many guys no how to fix them here in England and i am now out of action wot would the main isue be going from 1,50 to 1.36 ??? new the the bravo set up regards paul
Hardman,
What power level will you be at when the mods are complete?
I think a properly setup B1 would handle it, versus an XR with gears that wear out and break.
What year is your B1?
Dick
Dick
ultimately it will be in the 525-560 hp range. it's a 2002. What is needed for a proper set up? This is all new to me currently.
