42 cig new drives not producing. need help >
Old 08-03-2010 | 12:51 PM
What pitch are u running with the 4 blade 27 or 28 ??
natelee is offline
Old 08-03-2010 | 01:27 PM
offshoredrillin's Avatar
26 stock
offshoredrillin is offline
Old 08-03-2010 | 01:44 PM
I have been told before that you will actually go slower if you switch from a standard to an XR due to how the uppers are setup. I was told that the XR has straight cut gears that actually take more effort to operate causing a looss in speed due to the power it takes to overcome the differennce in gears.
but like i said i have just been told this. i have not done this on my own account. i have been told by a drive guy and another marine tech.
Fixxxer22 is offline
Old 08-03-2010 | 05:01 PM
Just for grins...2000 Tiger with 750hp, stock XR's and 5 blade Herrings spinning out...84mph.
Back4More is offline
Old 08-03-2010 | 05:09 PM
thats some good numbers. I think my buddys are 650 hp and with his stock bravos with 5 blades his best was 76.5
natelee is offline
Old 08-03-2010 | 05:16 PM
Stock 540 Bulldogs with 8/71's @ 6 psi...we're just guessing at the 750hp figure.
Old 08-03-2010 | 05:51 PM
straight hull? GLH had merc 600's in his with xrs and was at 82. Have you had any drive issues with the blowers and the amount of torque?
Old 08-03-2010 | 06:32 PM
Yeah, its a straight bottom...If I remember, GLH's 600's were a bit warmed over also.
He keeps up on them rather well...as soon as a problem shows up he has it opened up and looked at. A few gear sets and vertical shafts over the years but other than that he's golden.
Old 08-04-2010 | 09:45 AM
Registered User
My experience backs this up. I switched from B1X to the IMCO SC (same gears as XR) and lost a couple MPH. I will add that I went from 1.65 gears to 1.5 and had to change props....not sure if that factors in or not. Props were all four blade and back to original rpm's now.
russellhorn is offline
Old 10-27-2010 | 01:27 PM
Cigaretteman's Avatar
I always heard that sportsmaster lowers are for boats running 90 mph. plus.
Cigaretteman is offline
