Drive trim limit no longer working >
Old 09-22-2010 | 08:25 AM
Knot 4 Me's Avatar
Default Drive trim limit no longer working
Went to the river last Friday and noticed I can trim the drive all the way up now without getting into the trailer button. Bad sending unit on the gimbal ring? If so, how hard are these to change out?
Knot 4 Me is offline
Old 09-23-2010 | 07:38 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
If the screws are not siezed that holds them to the ring then thats a plus.. The real PITA is getting them run thru the transom plate.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 09-23-2010 | 07:58 AM
Knot 4 Me's Avatar
So, the wiring cannot be run without the bellhousing pulled off? Sorry, never had one go bad so I have no idea what I am dealing with here. If it is a case of just leave it alone and live with it I'm good with that.
Old 09-23-2010 | 08:02 AM
Unfortunately, yes the drive, bell housing & upper boot must be removed from the gimble ring at minimum. The thru hull in the gimble is above them and is tight the way it is to get in there to do what you need. J
Old 09-23-2010 | 08:56 AM
Knot 4 Me's Avatar
Thanks, Jamie. I'll tell the wife I have to trade the boat now.
Old 09-27-2010 | 07:23 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Pull the side cap off and see if the contact blade is touching the contacts
US1 Fountain is offline
Old 09-27-2010 | 09:36 PM
When my mechanic replaced my trim sender on my Baja, they did it with the drive still on and turned all the way to one side. They used the old wires to pull the new wires through. It was tedious and took them a while, but they did it without removing the drive.
Griff is offline
