Can you make a surface drive out of bravo >
Old 11-16-2010 | 03:32 PM
Smile You Might Want To (Google) The Mercruiser Blackhawk Surface Piercing Stern Drive.
The Bravo conversion has already been done in the past for you.
And if your serious about changing over, Then I have the perfect link for you.
http://www.offshoreonly.com/forums/s...rive-sale.html
lakematdude is online now
Old 11-16-2010 | 03:40 PM
I was going to ask about the blackhawk drives. How much hp can they take? Is this a possible solution for a surface drive/conversion?
rob vanharten is offline
Old 11-16-2010 | 03:54 PM
Not any more power than a pre X series ( thin floored)bravo
JaayTeee is offline
Old 11-16-2010 | 05:22 PM
Can you find kaama drives anymore?
TexomaPowerboater is offline
Old 11-17-2010 | 01:26 AM
I am having my motors built right now and I currently have trs's which I know will not live to long behind these engine's. I know everyone will want to say Konrad's which is fine but I like being different. I would really like to do a surface drive set up, a. they are unique b. they will hold the power c. I should be able to pull about 10 more mph on top end if set up right d. they look sweet throwing the rooster, and hanging off the back of the boat. But 50k plus on arnesons!!!!!!!!!!!!!
Bravo style drives are not any stronger than TRS drives unless you go to something like a BMax or SCX which is going to cost you 30-40k for the set up.
Best bet would be to find a set of SSM 3's, 3A's, 4's or 5's and recut the transom.
Griff is offline
Old 11-17-2010 | 09:04 AM
Tom A.'s Avatar
Originally Posted by Brad Zastrow
Many high performance boats can what I call, surface a Bravo drive. Fountain race boats are a good example. However I do not think you have the hull for a really high x-dimension. It will only blow out and probably not even get on plane. Maybe check with the factory on how high you can go.
Bingo! My Donzi runs that high x-dim and I have an an almost surface drive height as seen in the rooster tail. Not too many Bravo boats throw a rooster tail or as Brad said can! It really depends on the hull design. My boat was the Donzi in house boat for four years and I can tell you they had every size spacer, shorty, etc. on it to dial it in.
Attached Thumbnails Can you make a surface drive out of bravo-chesapeake10-2.jpg   Can you make a surface drive out of bravo-chesapeake10-15.jpg
Tom A. is offline
Old 11-17-2010 | 11:22 AM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
It needs a set of Arnesons!
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 11-17-2010 | 07:43 PM
Hey Rik, I have a formula 357 which has the trs set up currently. Is there any way to re use my borg warner transmission's, and leave the motor's where they are? Or do I need to move motors back and purchase the bravo conversion kit? Your product really is my 1st choice, I just am trying to get the cost down a little. What are my options with the trs/borg warner set up? Thanks!!!
Old 11-17-2010 | 08:32 PM
I think it would be easier and cheaper to just buy another boat then do every thing you are talking about. But then again dreams are free.
Jeff P31 is offline
Old 11-17-2010 | 08:33 PM
Buy a 357 with Kaamas already on it from the factory. There is a mint one for sale here in NC. Jeff Wurl
jwurl is offline
