1000hp drive
Old 11-21-2010 | 05:42 PM
  #51
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Originally Posted by campionchase910
Rik, I have a lead on two arneson 6's. I only need one. If I sell the other what is iinvolved to have the left hand rotation made to right? One is right and one is left; I am not familiar enough to know what is involved. Also how hard would it be to take my volvo transom rigging out to convert. Is there fibreglass and re-enforcing involved? Thanks in advance.
If you are getting two and one is currently RH then why change the LH to RH?
Either way, the internals of the LH can be swapped out to be RH and vice versa.
Converting from any I/O would only require our standoff box as it will cover the transom cut out and not require any glass work.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 11-21-2010 | 06:04 PM
  #52
One other route to consider:
http://www.weismann.net/Press%20Page...annDuoProp.htm
I have no idea the cost, I know PowerPlay "Steve 1" knows about this drive, he recommended it on another application.
bert4332 is offline
Old 11-21-2010 | 06:36 PM
  #53
Thanks Rik. I like the fact that there is no fiberglass work required. What is the stand off box worth. I only was wondering to convert the left hand to a right in order to sell it as I will only need the one.
campionchase910 is offline
Old 11-21-2010 | 06:46 PM
  #54
Standard rotation motors. The out drives handle the propeller (RH or LH ) rotations.
Rik I have two friends with ASD8-10s running lh and rh motors, and trannies. I am confused. I don't know how the drive could determine the rotation??
4bus is offline
Old 11-21-2010 | 10:18 PM
  #55
Rik's Avatar
Rik
That is not the drive he is asking about. I have counter rotating ASD8-10's also but not all ratios.
Rik is offline
Old 11-24-2010 | 09:32 PM
  #56
Originally Posted by kreed
Yepp!
Didn't think the 910 came as a single drive option. Well, you learn something new every day.
Go with something strong. Arneson.
______________________
Download wii games
Burn Wii games
ellyka112 is offline
Old 12-08-2010 | 06:21 PM
  #57
Default switching from xr to arneson
Can someone explain what is actually involved in changing from a Bravo Xr with ITs to a Arneson ? Does the transom assembly / motor ..etc need to come out ?? Is a transmission required ??
whataride is offline
Old 12-08-2010 | 08:06 PM
  #58
Rik's Avatar
Rik
You need to remove your engine in order to remove the Bravo Gimbel and transom assembly, engine bell housing and drive plate.
All the parts needed to replace it are included in the Arneson kit including transmission.
Rik is offline
Old 12-08-2010 | 08:42 PM
  #59
[QUOTE=ellyka112;3260738]Didn't think the 910 came as a single drive option. Well, you learn something new every day.
They should have made them all with single engines !!!!! Rode in 1 with twin 500efi engines and it was the illest handling thing I ever rode in . And no it was not the guy driving either.
Jeff P31 is offline
Old 12-08-2010 | 09:17 PM
  #60
GLH's Avatar
GLH
If you want to keep it 20 years Arneson.
If you want to sell it one day, #6.
GLH is offline
