How to remove the shield from the transom?? >
Old 12-13-2010 | 01:24 PM
Default How to remove the shield from the transom??
Im trying to remove the TRS shields from the transom.
I have tried everything but i cant get it loose.
Does someone have any good tips?
R4Bjurs is offline
Old 12-13-2010 | 03:55 PM
northernoffshore's Avatar
Glued on real good use wedges and beat them in.
northernoffshore is offline
Old 12-13-2010 | 04:08 PM
Default Fixx
if its really glued on their i use a portapower between the motor mounts with a 3''x3'' box tube and slight pressure..then i use efi intake plenum cleaner and spray around the housing several times and keep applying pressure..its takes about a week but it usually works with out damaging the gel..
FIXX is offline
Old 12-14-2010 | 12:54 PM
Thanks guys. i will try one of them. I get back with some results!
R4Bjurs is offline
Old 12-17-2010 | 03:04 AM
Finally.... Took 3 days i used wedges and portapower.
Only one left...
R4Bjurs is offline
