#6 oil pump question >
Old 01-21-2011 | 11:05 AM
Default #6 oil pump question
Can someone explain how they work and how often they fail or should be replaced? I read where a guy had one go bad and it fried the drive. Thank you
GOT POWER is offline
Old 01-21-2011 | 04:32 PM
marinetrans's Avatar
They only fail if: low oil,water in oil, metal in oil (gear wear,bearing wear), if drive was rebuilt after gear failure and never replaced pump,lose pump cartrige bolts. There are 2 alumn. wear plates between pump, check for wear.
marinetrans is offline
Old 01-21-2011 | 08:51 PM
weldcrane's Avatar
peter how are ya?
weldcrane is offline
Old 01-21-2011 | 10:26 PM
Originally Posted by weldcrane
peter how are ya?
Hey Bill, i have a couple of phone numbers for you, call me Mon.
Old 01-22-2011 | 10:37 AM
Thanks for the information. So you would not just randomly, let's say every 50 hours, need to change the pump, just if you rebuild?
