B-Max
Old 05-10-2011 | 07:34 AM
  #91
Originally Posted by waconda
Yes it does mix with water and for the life of me I don't know why that is on the top of your list. If your drive is taking on water you should fix it not keep changing oil. The Bravo Shop oil will last up to a 100 hrs so no need to spend $ 50-60 a gallon on amsoil + the Lucas additive x 3 changes= 75-80 dollars a service for a Bmax, now x that by 3 = $225-240 a year or $92.00 a year for The Bravo Shop oil.
I will post pic's on The Bravo Shop FB Page of what happens when you mix water with Merc oil and you maybe surprised.
http://www.facebook.com/#!/pages/The...51505554868867
endeavor1 is offline
Old 05-11-2011 | 07:18 AM
  #92
Panther's Avatar
Frank's Marine Service
Thanks I'll check it out. How long have you been marketing the oil? Dean never mentioned it. How many hours/years of testing have you done?
Any drive that's immersed in water should have an oil that allows it to mix with water IMHO. If you pick up something like a fishing line and tear a prop seal you may not know it until it's too late. PS, my "BMAX" drives do not have water issues and I've supported your product many years now. Any questions feel free to contact me.
Panther is offline
Old 05-11-2011 | 07:31 AM
  #93
SS930's Avatar
Wow, that's some fuzzy math, ever consider politics?
SS930 is offline
Old 05-11-2011 | 08:50 AM
  #94
I couldn't do any worse then who we have now!
waconda is offline
Old 05-12-2011 | 02:27 PM
  #95
From their website:
"We purchased the Bravo Shop in May, 2010. We currently own and operate Waconda Welding, Inc. in Union, NE which we opened in May 2002. At Waconda Welding we do welding fabrication and auto repair. Since we are close to two small lakes and own our own boat, we got into the marine repair service also. We are also an authorized Mercury parts dealer with a full line of Mercruiser Stern Drive parts. When we purchased our BlackThunder, it had the BMax drives on it. We thought they were great drives and when Dean decided to not continue to support or manufacture them, we felt it was a perfect opportunity for us to take it over.
This is a family run business. There is myself, my wife, and my two sons that work for the company.
We look forward to working with you, and making the BMax drive a better product and a reliable product for the industry.
Looks for us in Performance Boat Magazine and on their web-site.
Thanks,
John and Michell Pfahl"
http://www.bravoshop.net/BMax_Drives.html
Mike Mercury is offline
Old 05-12-2011 | 07:18 PM
  #96
+1 You can call me too....
I had to make up 6 of my own o-ring grooved washers to seal the upper to the gimbal. Also made a plug to keep the o-ring from collapsing into the shift pin dia. Never leaked since. That was 4 seasons ago. Only weak link for me is the vertical shaft snapping at the pinoin bearing sleeve dia. and the lower gear sets wearing out. Been using Mobil 1 75w-90 with a bottle of Lucas between the two.
I change the Gear Lube every season.
Back4More is offline
Old 05-12-2011 | 10:13 PM
  #97
I was just curious why you changed oil so much.
The base oil has been used in the marine industry for years and we added some new additives to it to make it even better. We are also testing some new oils at this time. We have all the major oils being tested against ours and hope to have the results by the end of June.
Heres the deal we are not bound by API or any other standard as to how to make the oil so we can make it fit the application we need. Where as API branded oils have to test within the parameters set for them by API for what ever rating they are trying to meet.
waconda is offline
Old 05-12-2011 | 10:19 PM
  #98
Cool
Lets talk some time
waconda is offline
Old 05-12-2011 | 10:25 PM
  #99
Its been my experience if the lower vert shaft is snapping off it is do to heat cause by the bearing fitting to tight in the bore of the housing. And also to thick of oil not allowing the the bearing to stay properly lubricated and causing extra heat and weakening the shaft.
Was this problem with the BMAX lower or the Imco Lower.
waconda is offline
Old 05-13-2011 | 09:22 AM
  #100
Yep, it's the IMCO lower. I also replaced the caged roller bearing that Dean and IMCO used with the Merc style rollers and sleeve. No more signs of heat on the race. Maybe thats why I have not broken one since. Knock, knock, (wood table)
