B-Max
Old 05-15-2011 | 09:03 PM
  #101
Originally Posted by Back4More
Yep, it's the IMCO lower. I also replaced the caged roller bearing that Dean and IMCO used with the Merc style rollers and sleeve. No more signs of heat on the race. Maybe thats why I have not broken one since. Knock, knock, (wood table)
Glad its working for you.
waconda is offline
Old 05-16-2011 | 07:40 AM
  #102
Panther's Avatar
Frank's Marine Service
Was the OD of the caged roller bearing you were using smaller than the Mercury bearing?
I too was going to change from the Dean's caged bearing over to the Merc bearing but the ID's are different. All the machinist I spoke with cautioned me from having the case modified to accept the larger OD Merc Bearing because unless it's in the fixture the drive was originally machined it wont line up perfectly. Now I just replace them every other season to be on the safe side. Bearings are cheap and my time doesn't cost anything.
Also gotta watch out the sleeve isn't too tight on your vertical shaft. It will tighten up the clearance between the shaft and the bearing wearing it out faster and making a lot of heat. I've been told to get my shaft machined and even turn down the race but I've had better luck ordering a few sets of bearings and using the one with the proper clearance. Apparently they're not all created equal.
Panther is offline
Old 05-16-2011 | 03:19 PM
  #103
I dont remember if there was a diffence between them on the dia.
I had the drive guy do the work.
Back4More is offline
Old 05-16-2011 | 03:53 PM
  #104
Merc 2.130
Bravo Shop 2.061
waconda is offline
Old 05-16-2011 | 04:00 PM
  #105
Don't know if we're talking about the same one. Here is a pic.
Old 05-16-2011 | 05:02 PM
  #106
Thats it!
waconda is offline
Old 05-16-2011 | 08:14 PM
  #107
Originally Posted by waconda
Thats it!
I like the Catalog pages with the nice pics on your site.
Old 05-16-2011 | 09:37 PM
  #108
Thanks. I don't have a lot of time to update the site like I should. So if you don't see something, make sure you call.
waconda is offline
Old 05-17-2011 | 09:00 AM
  #109
So what's the cost for a B-Max Drive?
vettex1 is offline
Old 05-17-2011 | 09:15 AM
  #110
$14200.00
waconda is offline
