2000 model year bravo 1 spline size?
can somebody tell me what spline my 2000 bravo 1 is?
i am trying to make a deal on a prop, and want to make sure i am buying one that will fit.
i could wait till i got home and count the one in my living room, which i need to send in for hub replacement, but i was hoping to find out during work hours.
it is advertized with the mercury cushion loc 15 spline? versus the universal hub system i am familiar with, and i am being told it can be quickly changed between the 15 spline /and the 19 spline.
thanks in advance....
doug hunt
doug hunt
In 2000 it should use the universal hub, You'll either have a 1.25" or 1.0" shaft. Order the appropriate adapter.
I was unaware of any propeller mfg still making Bravo style propellers with splines. I thought most everyone was using the square interchangeable hub design.
yes, my current props all use the square hub aka universal hub systems, however this prop is listed using a cushion loc hub system:
CLM200 Power Tech Premium Cushion Lok Hub System
listed as having the cushion loc 15 spline .
the seller says it can be changed from 15 to 19 spline "quickly" , and i just want to make sure it will fit before i try it.
this info comes from another seller of the powertech props website, and under the mercury/mercruiser hub tab, it lists both this cushion loc hub system AND the universal hub system(square) that i am familiar with. I just have never seen this "cushion loc" before so i am not sure what i would be getting.
