Bravo to #6 prop shaft conversion >
Old 03-08-2011 | 04:56 PM
Default Bravo to #6 prop shaft conversion
What is the name of that shop that was doing the #6 prop shaft conversion to the bravo lowers?
Located in New Jersey?
or was it New Jersey Shore?
Oh yea, Snokee Marine?
Just kidding. Do need the name of that shop.
Pro (something)
ROTAX454 is offline
Old 03-08-2011 | 06:08 PM
JasonSmith's Avatar
IMCO makes a 1 7/16 shaft that is the same diameter as the #6.
JasonSmith is offline
Old 03-08-2011 | 06:22 PM
Boater8987's Avatar
Airking
Here you go. Talk to Rolf or Fran
http://prorocracing.com/
Shoot me a pm if you want to know the results on my cat. I went back to the bravo set up.
Gary
Boater8987 is offline
Old 03-09-2011 | 12:04 PM
Ahhhhhhhhhh. Thanks Boater8987.
ROTAX454 is offline
Old 03-09-2011 | 02:35 PM
RMPRam's Avatar
I'm a little confused. Why would you want to put a #6, or for that matter any propshaft the same size as a #6, in a Bravo? It would then be the strongest component in the drive and you would begin to find the weakest "link" in the other internal components. I realize that you would then be able to use props that were not available for the Bravo. Is that the reason for the "swap"?
RMPRam is offline
Old 03-09-2011 | 02:47 PM
RMPRam's Avatar
I believe that the od on a #6 propshaft is 1 7/8", not 1 7/16"
RMPRam is offline
Old 03-09-2011 | 08:33 PM
Boater8987's Avatar
Airking
Yes that was my reason. Along with Rolf stating that the drive may last longer due to less harmonics than the bravo style props create. Did not work with my Spectre. You can read this about my experience if you want to.
http://www.offshoreonly.com/forums/d...-lost-mph.html
