gear lube
Old 07-16-2011 | 08:56 PM
  #161
2112's Avatar
Originally Posted by articfriends
My 5 gallons of NEO showed up last wek, I will be giving it a shot this summer, hope it is as good as claimed, thanks Jason/John / Bravo shop
Any thoughts so far?
2112 is offline
Old 07-16-2011 | 09:45 PM
  #162
What were you running before and did you gain any speed?
Not my boat. My good buddies boat. He loves how they shift so far, perform and is very happy with the results as we speak. I can not confirm any increases/decreases, but I do know that since the switch, hes bumping the rev limiter again with his 32p bravos.
07DominatorSS is offline
Old 07-17-2011 | 01:23 AM
  #163
Default Confusing ???
Originally Posted by crayolacrazy
I have read that Teague uses amsoil 10 w 40 mcf in his no.6,s I read on amsoils web that this is equal to 80 /90 weight gear lube .So I wonder if this can be used in a bravo ?
Why do you want to use motor oil in an outdrive? No such thing as 10 w 40 gear lube.
This is one of the best
http://www.amsoil.com/storefront/agm.aspx
When it comes to outdrives, synthetic lube is superior.
TEXASRPM is offline
Old 07-17-2011 | 08:19 AM
  #164
Has anyone used Brad Penn gear oil????????????????
26awesome is offline
Old 07-17-2011 | 09:30 AM
  #165
No doubt that the AGM is a great product. And yes, on a weight scale, gear oils and motor oils are classified differently and a 20w-50, is virtually the same as a 75w-90. The AMSOIL 10w-40 has a gear lube rating to it, and being a bit lighter viscosity, should in theory allow you to spin your props faster.
Old 07-17-2011 | 07:10 PM
  #166
articfriends's Avatar
I have put less than 10 hours on the boat this year, been breaking in a new set of lower gears that were Cryoed, isoed and DLC coated, I want them to last. Things have been un-eventful so far, oil still looks like new, nothing in my outdrive oil filter, I added a prefilter before the drive oil pump because the metal from the last set of gears destroyed the diaphram in the circ pump. I will post after I beat on it hard, Smitty
articfriends is offline
Old 09-08-2011 | 12:36 AM
  #167
Default Neo oil
How do you get onto the Bravo site? When I do it asks for a password?
timjschmidt is offline
Old 09-08-2011 | 07:09 AM
  #168
www.bravoshop.net
waconda is offline
Old 09-08-2011 | 08:01 AM
  #169
Mr Gadgets's Avatar
Charter Member #601
just tried to get to the bravoshop. net and every time you click on a menu item, it asks for a password and username, as Tim said.. ????
Mr Gadgets is offline
Old 09-08-2011 | 08:30 AM
  #170
OK it's fixed, We added some parts last night and must have clicked on the wrong thing.
waconda is offline
