gear lube
Old 07-14-2011 | 01:29 PM
  #151
Mine are still running strong. Oil isnt even begining to look or smell burnt like the merc oil would by now.
endeavor1 is offline
Old 07-14-2011 | 03:59 PM
  #152
Quinlan's Avatar
Originally Posted by JaayTeee
mine are still kickin'
Mine TOO!!
Well havent put the oil in yet but I have 15 hrs on my new uppers so oil change comming soon.
I just SO DAMN happy to get 15 hrs outa some drives!
Quinlan is offline
Old 07-15-2011 | 08:46 AM
  #153
Originally Posted by SS930
You better get Nellie started on a 2nd job!
If I blow an IMCO Extreme, we'll ALL be getting second jobs! Hahaha!
kreed is offline
Old 07-15-2011 | 06:48 PM
  #154
onesickpantera's Avatar
I run Wal-mart brand 5w-30 motor oil. The thinner oil gives me an additional 500 rpm and 5-6 mph! I just change it more often.
onesickpantera is offline
Old 07-15-2011 | 07:06 PM
  #155
JasonSmith's Avatar
Awesome choice!
Do you run split-fire spark plugs & Accell wires too?
JasonSmith is offline
Old 07-15-2011 | 09:26 PM
  #156
Originally Posted by JasonSmith
Awesome choice!
Sam Walton was a real sharp guy. Never knew he had figured out the Bravo deal.
Live and learn I guess.
RaggedEdge is offline
Old 07-15-2011 | 09:47 PM
  #157
Update on AMSOIL MCF, Motorcycle 10w-40, in 2011 Bravo X drives with new Merc 502's in front of them. So far, about 25 hours, pulled one top cap, and gears are perfect!!! In that duration, one poker run, and some decently longer runs around the lake. Boat will run 91.7 GPS, so....
07DominatorSS is offline
Old 07-16-2011 | 08:26 AM
  #158
articfriends's Avatar
Originally Posted by John the Drive Man
It all depends on what Brand of oil you are selling, in what is the best. It's all an opinion, period.
Never have I had a drive fail because of oil, if I'm using the right product. Mercury has more test time on oil when it comes to out drives and outboard lowers than anyone in the industry. In all my 45 years with the Mercury Outdrives, have I had a drive failure because of oil. And I have 15 World Titles under my belt. It's not about just oil, it's how the gears and bearings are set according to the HP. Gear setting is the most important. No matter what. But everyone out there tends to always blame the oil first. I guess that's the easy way out.
John, I would have to respectively disagree, I could not get lower gears to last past 15 hours with merc hp oil (1050-1100 hp/1000 plus ft lbs of tq), I didn't have much better luck with Royal purple but the amsoil sever gear has made a night and day difference, I don't sell the stuff either. I found the best gear life in the lower with B/L set between .014-016 with gears that have been cryoed and iso rem polished, I assemble my own drives. I am getting around 60 hours from lower gears these days and the uppers are over 350 hours , Smitty
articfriends is offline
  #159
What were you running before and did you gain any speed?
Old 07-16-2011 | 08:34 AM
  #160
Originally Posted by cprperformance
Well, put in the 75/140 severe gear 8 qts. to 1 qt. lucas and so far very happy with the results. Shifts much softer and smoother in and out of gear. Won't know about gear life until tear down, but I think that this is going to be a very benificial formula.
Did your boat slow down from the thicker oil? When I was doing extensive lower gear testing a few years back I found the 85/140 Royal purple slowed my boat down about 4%, In testing that was almost back to back boat ran 92-93 with 80/90 and wouldn't break 88-89 mph with the thick stuff(I had less power then than now), being supercharged with a inner-cooler boat pretty much runs the same number too regardless of weather conditions on typical Mi days unless air is really good with low ambient temp, Smitty
