transom assm identification >
Old 04-10-2011 | 04:44 PM
berns29scarab's Avatar
Default transom assm identification
0L811795 assm id #
trying to verify if this is an HP assm
berns29scarab is offline
Old 04-10-2011 | 04:48 PM
I was told id it has stainless side hinge pins its an HP. The diff between 2 or 4 screws is age of it. Supposedly later models use 4 screws on the hinge pins
Old 04-10-2011 | 04:58 PM
Its an early model HP gimbal assembly.
Why is the U-bolt not tight
brian41 is offline
Old 04-10-2011 | 05:07 PM
Good eye Brian, but still missing a part.
See item #23.
http://www.mercruiserparts.com/Show_...Steering+Lever
ROTAX454 is offline
Old 04-10-2011 | 05:23 PM
Unsure why they were loose and good eyes are right. Thank. You. Any diff between old style n new style other then 2 vs 4 screws in hinge pins?
Old 04-10-2011 | 05:38 PM
You can now use parts from the ITS unit to still use the electric trim senders. Other changes unknown to me. PM MrGadgets on this site. He can help.
ROTAX454 is offline
Old 04-10-2011 | 11:35 PM
Old 04-11-2011 | 08:04 AM
Torque specs on a transom assembly anyone?
Old 04-11-2011 | 07:52 PM
sac
Starting with the middle fasteners torque in an "X"pattern several times until a torque of 25 ft. lbs. is acheived
sac is offline
