Drive ratio
Old 05-02-2011 | 09:51 AM
Default Drive ratio
How can you tell if your Bravo is a 1.5/1 or a 1.36/1 drive? My boat had a supercharged 502 in it and now it has a NA 468 making 450 hp and it wont turn over 4400 rpm with a 25 p mirage. Everyone is saying I should be able to easily turn over 5,000 with this combo. So I was thinking making the ratios in the drive are different. There are no numbers on the drive anywhere to tell. Is it possible to tell the drive ratio without tearing the drive apart?
cdail28590 is offline
Old 05-02-2011 | 10:29 AM
Normally it would be on the upper part of your drive like this.
What boat is this package in? To spin a 25 @ 5000 should put you around 73-75 mph. What is your top end goal? If possible, find your serial number and contact mercury, or your local merc shop.
A.O. Razor is offline
Old 05-02-2011 | 10:34 AM
I called Mercury and gave them my serial number. They told me what gear ratio I had.
UrbanDisturbance is offline
Old 05-03-2011 | 04:23 PM
There is no serial # on the side of the drive. There is a serial # on the outer transom assembly. My boat is 24 Python and I have a aritcle where one of these boats came from the factory with a supercharged 454 and a 1.36 drive. I know my prop has had some work done to it as the tips have been cut down so I don't think I would call it a true Mirage 25p. I was going to try my buddies bravo 26 and 23 mirage + this weekend but I didn't get a chance.
Old 05-03-2011 | 04:56 PM
The 26 Bravo 1 will lower your rpm even further. What is your gps speed with the 25 @ 4400rpm.
JMS322 is offline
Old 05-03-2011 | 04:59 PM
What HP and speed did you have with the supercharged motor? I owned a 24' Python w/ stock 502 MPI B1 1.5 gears. It would run 72 gps.
What does the new motor have in it? And did you use a dyno. That way you can tell excatly where your power curve is.
The reason I ask is becasue 2 weeks ago I dropped in a new motor. Only saw 4,900 rpms. After much research figured out my cam was degreeded in wrong. So I removed the motor and reset the cam ICL to where it should be. I was 5 degrees off which makes a huge difference lost all bottom end power and moved the power curve up so high I couldnt get over the hump. Not to mention the water reversion problemn.
Hard Charger is offline
Old 05-04-2011 | 11:24 AM
The motor is a 468 with a custom Bob Madera cam in it. It made 451 hp and 511 ft/lbs torque at 5200. My GPS speed at 4400 was 61 mph.
Old 05-04-2011 | 03:46 PM
Hmm. Something is surely not right. If your drive is a 1.5, then your slip is good. 12%, and you should see low 70's @ 5200, and that seems about right for the setup. If your drive is indeed a 1.36, your slip is 21%, and that is somewhat high. You mention that the prop has had work done, so a non labbed Mirage+ could maybe be a good baseline prop. Before ripping the motor apart, I would try a 23" and 25" M+ and see what happens. In best case, you might just be over prop'd, and a 23" on a 1.36 should be close. Alternatively a 22" and 24" B1 prop could also be good starters. What is you x-dim?
Ps. Ignore the 72-75 @ 5000 rpms in my earlier post. More like 70+. Typing when tired I guess.
Old 05-05-2011 | 08:31 AM
I will try my buddies 23 mirage +, hopefully this weekend. The x dimension is set at factory levels. I didn't change it when I redid the transom. I was hoping to get 75 out of this combo. I guess theres no way to determine the drive ratio without tearing the drive apart?
Old 05-05-2011 | 09:05 AM
If all the stickers are gone and no serial you can pull top cover and count the number of teeth on the gear.
Go on mercruiserparts . Com and enter the seriAl numbe you have of transom and see what pops up. If it's all stock should lead you in right direction. I had a python and to have a 1.36 it would be an earlier one.
GTOFFSHORE is offline
