What Drive?
Old 07-28-2011 | 05:58 PM
  #71
Originally Posted by A.O. Razor
kjm5125
Did you recive your drives? A few pic's of the drives and parts before install would be cool
Project started this past Monday, my mechanic said he would take pictures. I'll post when he sends. I'm hoping he will be done tomorrow.
kjm5125 is offline
Old 07-28-2011 | 06:17 PM
  #72
Originally Posted by ThisIsLivin
That's what I'm afraid of. I'm having problems now with a Bravo 1 prop that won't take any trim. Mid 80's with a surface drive, I'd be crying. I'm rebuilding my NA 524 BBC and hope to be in the high 90's with my Bravo 1.
Well you also have to remember that his 28 AT is NOT a velocity or a Kryptonite. it is a heavy straight bottom that relies on bow lift to run well. A bravo AT with 800hp or so only runs in the mid to high 80's depending on setup.
Philm is offline
Old 07-30-2011 | 02:36 PM
  #73
Default Went to the shop today
Conversion should be done next week!!
Attached Thumbnails What Drive?-img00220-20110730-1253.jpg   What Drive?-img00216-20110730-1227.jpg   What Drive?-img00217-20110730-1227.jpg
kjm5125 is offline
Old 07-30-2011 | 11:52 PM
  #74
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Nice
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 07-31-2011 | 07:06 AM
  #75
Looks good, enjoy. Still plenty of summer left.
SkiDoc is offline
Old 07-31-2011 | 08:29 AM
  #76
I'm impressed.
40gt is offline
Old 07-31-2011 | 11:53 AM
  #77
Default Strainers
Current set up has water pick ups for the Intercoolers and no strainers.
Do I install sand strainers for the Intercoolers and then install another set of strainers and pick ups for the engine?
-OR-
Feed everything through the existing pickups with just two strainers? My concern is will there be enough water volume to feed the engine and coolers?
I've been looking at Hardin Marine Strainers
http://www.hardin-marine.com/c-1101-sea-strainers.aspx
kjm5125 is offline
Old 08-01-2011 | 06:10 AM
  #78
You'll need two pickups per engine. There is more than one way to do this but I believe that this set up is the best. One pick up for the intercooler to the Hardin strainer that you posted. Pressure feed the intercooler. No flow needed at idle. You will need to adjust it for pressure so will need a temporary guage. The second pick up to a strainer then pump. You will need to adjust pressure as well. Both pickups should have cutoffs and pressure relief valves. Set up will take some experimentation to get right.
SkiDoc is offline
Old 08-01-2011 | 07:34 PM
  #79
Thanks, going with 4 pick ups and separate strainers.
kjm5125 is offline
Old 08-02-2011 | 06:28 AM
  #80
Looks sweet.
Rik. Are the extension boxes supposed to sit below the notch? It looks like they do.
A.O. Razor is offline
