Tie Bar Touching Mufflers >
Old 05-18-2011 | 02:55 PM
AIRFOIL292's Avatar
Default Tie Bar Touching Mufflers
LOOKS LIKE THE MUFFLERS WILL COME IN CONTACT WITH THE TIEBAR.
I TOOK MEASUREMENTS AND LOOKS LIKE WHEN DRIVES ARE ALL THE WAY UP.TIEBAR WILL HIT GIBSON CLAMP ON MUFFLERS.I HAVE IMCO HYDRAULIC STEERING WITH TIEBAR.HAS ANYONE HAD THIS PROBLEM.IS THERE A REMIDY.THANKS
AIRFOIL292 is offline
Old 05-18-2011 | 04:08 PM
EWPE's Avatar
You can put spacers in your trim cylinders to reduce the amount your trim cylinders extend. Merc part No. 15768A3
EWPE is offline
Old 05-18-2011 | 05:21 PM
AIRFOIL292's Avatar
Thanks for the info on the spacers.Can I relocate the tie bar?
Old 05-18-2011 | 05:50 PM
I have gaffrig switchable mufflers on mine and the tie bar hit when it was mounted to the top of theplate that's bolted to the drive. I pulled the bolt out and mounted it to the bottom side. Works fine
Drock78 is offline
Old 05-18-2011 | 06:04 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Why not just reset your trim limit?
US1 Fountain is offline
Old 05-18-2011 | 06:38 PM
There ya go...
Back4More is offline
Old 05-18-2011 | 07:01 PM
Too Stroked's Avatar
Trim Limit limits how far your drive(s) go up in the trim mode. It doesn't affect how far they go up in the trailer mode. If he's hitting in the trim mode, he's got a very unusual exhaust setup.
Too Stroked is offline
Old 05-18-2011 | 07:20 PM
Ginger or Mary Ann?
Yes, that I know. For some odd reason was thinking when in fully trimmed position, not trailered trim.
Have you considered the tie bar that mounts at the rams?
Old 05-19-2011 | 09:03 AM
AIRFOIL292's Avatar
I have IMCO steering center triangle plate.Tiebar will hit in trailer mode.Is it OK to remove tiebar and locate to the lower ram connection on the drive using the sadles????Has any one been there before with this situation??
