-   -   XR Trim Problems? (https://www.offshoreonly.com/forums/drives-lower-units/254215-xr-trim-problems.html)
bsboss 05-23-2011 11:28 AM
XR Trim Problems?
Finally got the boat on water last weekend and trying to figure out the drive trim. From the hand control it only trims down, not up. The trailer trim works. Anybody have any ideas what I need to look for?
Blueabyss 05-23-2011 05:28 PM
Trim
Read my posts on this thread.. Same problem and fix.
http://www.offshoreonly.com/forums/g...djustment.html
Chris
bsboss 05-23-2011 05:43 PM
Chris
It seem to work when engine is off, can't here the pump running with engine to loud. I can tried to check it out some more next weekend. Still thank it could be limit switch? Looks like previous owner may have been jacking with wires too.
Blueabyss 05-23-2011 08:51 PM
Trace down the limit switch wires. They are close to the trim pump. Unplug them and us a jumper wire to go between the connectors by the pump. Not the ones going to the outdrive but the ones they plug into. You will need 2 male conectoes and 2 inches of wire.
Chris
bsboss 05-24-2011 11:04 AM
Chris
Thanks, I will look into it.
bsboss 05-24-2011 11:07 AM
blueabyss,
The drive trim gauge wasn't working either, so I unpluged a 3 wire connector an plugged it into a unused 3 wire plug and now it works. Should there be a unused connector?
Blueabyss 05-24-2011 05:40 PM
Where is the connector at? By the trim pump or up behind the engine. The trim limit switch and sending unit have 2 wires each. 2 go over the trim pump and 2 up behind the engine. They are bullet connectors not a a plug so someone else on here might need to us. But if it is working then great.
Chris
bsboss 05-25-2011 08:00 AM
Chris
There is two 3 wire connectors close to the trim pump, I just switched them and now the gauge works but not the trim up on throttle. I will look at it again this weekend and try to get picture? Thanks for your input.
bsboss 05-31-2011 10:59 AM
Outdrive trim up now works until motor starts. After motor starts only will trim down. To trim up I have to use trailer trim up button. Any suggestions?
GTOFFSHORE 05-31-2011 11:13 AM
Power for pump needs to be hooked up directly to batt. Maybe there is a bad ground but something is cutting power to pump once its running still sounds like trim limit switch. Trailer switch over rides that and works pump.
