TRS BW tranny to inner transom mount alignment >
Old 06-06-2011 | 11:53 PM
Rookie's Avatar
Default TRS BW tranny to inner transom mount alignment
So I have an alignment issue and I think I am missing a washer or shim. Does it go from; Inner transom mount UP.
1. Nut
2. Inner transom mount
3. Washer/shim with rubber coating???
4. Transmission mount from the tailstock
5. Washer
6. Spring
7. Bolt
Does anyone know where I can look at a microfiche for this?
As always thanks!
Rookie is offline
Old 06-07-2011 | 12:43 AM
No that's not right Jason. Steel washer, fiber washer and spring go between the mounts. Watch you email. I'm sending you the page out of the manual.
picklenjim is offline
Old 06-07-2011 | 01:11 AM
This diagram doesn't show the fiber washer under the top steel washer like the manual and this diagram also shows a washer under the nut at the bottom where as the manual doesn't. However neither of these differences should have anything to do with alignment.
http://www.perfprotech.com/store/ass....aspx#assembly
Old 06-07-2011 | 07:06 AM
Rookie's Avatar
Jim, Thanks for your help once again.
I do not know if everything was there before I started this project. I always had a problem installing my drives.
Rookie is offline
