Preventing external shaft seal failure? >
Old 06-22-2011 | 09:57 AM
SS930's Avatar
Default Preventing external shaft seal failure?
Obviously the external portion of the shaft seal is not lubricated and is exposed to the elements. What, if anything, do you guys use to keep this seal from rotting? Silicone lube of some type, marine grease... ???
SS930 is offline
Old 06-22-2011 | 10:49 AM
What drive seal ? Or what seal you talking about?
John the Drive Man is offline
Old 06-23-2011 | 05:46 AM
SS930's Avatar
The external prop shaft seal, specifically on #6's if that helps.
SS930 is offline
Old 06-23-2011 | 08:12 AM
The external seal of a #6 is really a wiper seal for keeping water out. I have found using 101 grease works best for me. I use between each seal and around the out side of external seal. I have never had a problem. I do a lot of 6's on production performance boats, non-racing. You can call me if you have further questions on that at; 954 237 0332 ask for John.
Old 06-23-2011 | 08:50 AM
SS930's Avatar
Thanks for your input John.
SS930 is offline
