Bravo 1 change
Old 06-30-2011 | 04:26 PM
Default Bravo 1 change
I have Bravon 1 drives on whippled built 502s approximately 750 HP each. Understand playing with fire. What woudl be best change on drive without redoing transom?
Mama's Fault is offline
Old 07-01-2011 | 06:50 AM
Bmax
waconda is offline
Old 07-01-2011 | 08:55 AM
fireboatpilot's Avatar
RIPSTA Racing Team
I thought BMax was done? Wern't they another beefed up Bravo casing still using Bravo gears anyway? Imco SC's are the same deal, JUNK Bravo gears. Saving my pennies up for the SCX's. Seem to be the easiest swap from a Bravo. Change the gimble bell and bolt on the upper with much bigger gears. They can also use the SC lowers without much loss in speed. I was hoping to pick up some used SCX's but so far I don't see any popping up. Guess no ones broken any yet?
fireboatpilot is offline
Old 07-01-2011 | 12:01 PM
JasonSmith's Avatar
Bmax is far from a Bravo.
JasonSmith is offline
Old 07-01-2011 | 12:29 PM
ARNESON 7M you just have to cut the transom hole alittle bigger and their faster than any bravo or equivelant drive
47EXCALIBUR is offline
Old 07-01-2011 | 01:28 PM
RIPSTA Racing Team
My question was wether or not BMax went under or not? Is the 7M the one that doesnt need a trans?
Old 07-01-2011 | 01:51 PM
Smitty's Avatar
All Arnesons need transmissions, that is partly why they don't break. The trans is in an extension box.
Smitty is offline
Old 07-01-2011 | 01:54 PM
BDiggity's Avatar
John (waconda) is the new owner
http://bravoshop.net/BMax_Drives.html
BDiggity is offline
Old 07-02-2011 | 07:40 PM
Mr Gadgets's Avatar
Charter Member #601
SCX, helmet change on the gimbal.. 500hrs behind 825hp, 36' Apache, Vortec chargers. Lower gears started to flake. Upper gears are still in great shape. He runs it hard...
Mr Gadgets is offline
Old 07-03-2011 | 08:32 AM
I second that. And the Bravo conversion comes with everything excluding prop, and you'll be trouble free. The upgraded bravos has their issues too.
A.O. Razor is offline
