Trim settings not holding >
Old 07-01-2011 | 05:17 PM
Default Trim settings not holding
When I set the trim to a certain point I must keep adjusting the trim up to maintain the desired setting. I rebuilt both trim cylinders with no change . If I leave the drive up when Im done using the boat the following morning the drive will drop down completely. Are there check valves in the trim pump that can be cleaned or replaced?
tbanzer is offline
Old 07-01-2011 | 08:52 PM
What drive and pump might we be talking about?
picklenjim is offline
Old 07-02-2011 | 12:04 AM
That would probably help, Bravo drive, not sure what pump, its the original from when the boat was built in 2000.
tbanzer is offline
