Shift cable adjustment >
Old 07-25-2011 | 12:33 AM
Default Shift cable adjustment
I just had a new shift cable/booth installed in my '94 scarab, 5.7 , Alpha One. When I raise the prop for shallow water , I am not able to shift.
Is there a limiter that keeps from shifting in gear if the prop is too high??
Thanks for any advise.
scarab94 is offline
Old 07-25-2011 | 12:29 PM
seafordguy's Avatar
I don't believe there is a limiter, but you are playing with fire raising the drive way up and running it in shallow water - U-Joints dont like being treated like that.
seafordguy is offline
Old 07-25-2011 | 12:49 PM
It sounds right. Like you said, there is no need to run in the trailering position.
scarab94 is offline
