loose drive
Old 08-22-2011 | 08:33 PM
Default loose drive
I have a 29 Scarab with twin 350's and Alpha 2's .. One of the drives will move back and forth a few inches the other is tight. It is not the bushings it seems to be in the steering. Is there a way to tighten it ? ..thanks
Scarab29 is offline
Old 08-23-2011 | 08:48 PM
If all bushings look tight look at the swivel shaft that is if they are similar to a bravo, if that is good make sure you dont have air in the lines and just needs to be bled
firehawkcat is offline
