Couple TRS questions... >
Old 10-02-2011 | 08:47 PM
Default Couple TRS questions...
1. Drive showers, yes or no and if yes what kind and where to buy.
2. Tie bars, should the connections stay centered or is ok for one side to lean forward and the other backwards.
s022mag is offline
Old 10-02-2011 | 10:22 PM
No drive showers needed and I don't think anyone even makes them for TRS.
Griff is offline
Old 10-03-2011 | 09:33 AM
BDiggity's Avatar
my drives are off, but i think i noticed my tie bar having a lean on each drive when removing. Are you talking about how it mounts to the ball?
BDiggity is offline
Old 10-03-2011 | 05:44 PM
No. How it mounts to the drive. One leans all the forward and the other leans all the way back.
s022mag is offline
Old 10-03-2011 | 06:31 PM
The mounts should be at the same angle like in the pic of these TRS drives http://www.offshoreonly.com/classifi...o41962-en.html
Griff is offline
Old 10-03-2011 | 07:47 PM
you should be able to move the tie bar mounts forward and backward. If you cant, something is wrong. I don't know exactly why they made it that way. My guess is so it doesnt bind or put unnecessary pressure on the drives when one is up and one is down.
Dangerous Dave is offline
Old 10-03-2011 | 09:36 PM
I can't budge them at all it would take a rubber mallet probably. I'll try and get a photo tonight and post it.
s022mag is offline
Old 10-04-2011 | 08:47 AM
BDiggity's Avatar
OK yes mine were mounted like the pic Griff posted. It took a lot of work w/ the mallet to get them off.
BDiggity is offline
Old 10-04-2011 | 07:58 PM
Well I just figured out that one drive is higher then the other one and the reason why is cause my individual trim switches quit working and the only way I can raise and lower the drives are with the one trailer switch so I can assume that over time on drive probably raises and lowers faster then the other which puts the drives off then screws with the tie bar.
Pier 53 out of cedar point marine fixed my switches but that only lasted about a day. Now I have to find out what they fixed and fixed it again.
s022mag is offline
