#7 drives?
Old 11-21-2011 | 01:15 PM
Default #7 drives?
Hi.
I have found a pair of #7 drives with 1:1 ratio for diesels but i can't find any info about these drives, are they the same as #6? is there parts for them?
Regards
Jocke
Jorekore is offline
Old 11-21-2011 | 01:37 PM
I'd suggest you search around here, it's been up before.
Don't know much about them, but they are not like the #6's. You might be able to bolt on a #6 lower, but I'm not sure. The lower is very different. They where not in production for long, not a big hit. If you need #6's, I'd suggest you look for #6's.
A.O. Razor is offline
Old 11-21-2011 | 01:53 PM
tcelano's Avatar
#7's were designed for use with diesels, hence the high ratios. They share some parts with the #6's, but the ratios were all different, and I think the lower is different entirely.
tcelano is offline
Old 11-21-2011 | 01:59 PM
Thanks, is it possible to find spareparts for them? i'm thinking of using them with diesels but if it is impossible to find parts i will have to go with something else.
What are they worth with everything including props and steering?
Jorekore is offline
Old 11-21-2011 | 02:44 PM
Here are the parts for the 7 drive to look through.
http://www.mercruiserparts.com/selec..._nbr=SSM+SEVEN
lakematdude is offline
Old 11-21-2011 | 03:01 PM
It seems that there aint to many parts avilable for them.
The lower gear seems much bigger than both dry and wet sump 6.
Jorekore is offline
Old 11-23-2011 | 06:57 AM
What could a pair of ssm 7 be worth?
Jorekore is offline
Old 11-23-2011 | 12:29 PM
Don't have the answer to your question, but got a question.
Have you already purchased the drives? You should look for something else. Depending on your max rpm, you might not need a high ratio. I remember reading some info about prop speed being the key to good diesel performance. You could look for a set of ASD #8's. Stronger and lighter than a #6, and have shown to work great with not only gas, but also diesels. What kind of boat are they going on, and what is your budget for drives?
Old 11-23-2011 | 02:57 PM
No i have not bought them yet, if i want i could trade them for my chris craft stinger 312.
Yes i would rather have arnesons but the boat (scarab meteor 5000) has a notched transom and do not know if that would work, i had ASD 8 with 16" dropboxes on my last boat a chris cat and they're great.
ASD8 without dropbox 1:1 ratio would be the best choise and they're less expensive than most speedmasters.
Jorekore is offline
Old 11-23-2011 | 04:00 PM
Thumbs up
According to Rik from Arneson, notches are not necessarily an issue. Many notched boats run ASD's. As an example in this thread kjm5125's Formula runs ASD#7M's http://www.offshoreonly.com/forums/d...hat-drive.html
Fountains, Outerlimits ect. ect. ect. It should not be a problem.
