do i need and alignment tool or tool to do gimbal bearing >
Old 12-12-2011 | 05:55 AM
Originally Posted by lowfunds
if this is a bravo and you do the job on the boat you are going to have a helluva time drilling and tapping the 2 holes in the housing to remove the upper swivel pin. the housing is about 3/4 to a inch thick up there.
Use the JR method, it is eash to drill, about 1/8" thick there. Also leaves the drive looking much better, and is very easy to access the pin.
http://www.jrmarine.com/instructions.htm
apollard is offline
Old 12-16-2011 | 08:23 AM
All you need is a Blind Hole Puller set and you got everything you need to pull any Gimbal Bearing. That's all I've ever use. And I do a lot of them.
John the Drive Man is offline
Old 12-16-2011 | 10:56 AM
Whoya, you do have some cool tools. This one is by far may favorite that you have listed
<http://www.ebay.com/itm/TROJAN-INTEN...item3f0f331b36
4bus is offline
Old 12-16-2011 | 02:01 PM
Plum_Crazy's Avatar
That's a shaft insertion tool.
Plum_Crazy is offline
