Bravo help please
Old 01-18-2012 | 12:50 AM
Default Bravo help please
Just to make sure about this, a bravo 2 upper is the same as a bravo one. If the gear ratios are the same etc. A friend just got a bravo 2 1.5 diesel x drive and cant use it because of wrong ratio. I don't care about the lowers since I use a shorty. Hope someone can confirm this before I get it.
David
GTOFFSHORE is offline
Old 01-18-2012 | 06:18 AM
EDIT: Did not know about the diff. on the bearing and BII gears. Sorry about the wrong info, I stand corrected.
A.O. Razor is offline
Old 01-18-2012 | 10:11 AM
Thank you. I was pretty sure it was the same but wanted to double check.
Old 01-18-2012 | 10:18 AM
Mr Gadgets's Avatar
Charter Member #601
David,
according to this chart from Bam's Site. The 1.5 Diesel B2x uses the same upper gear set as the B1x 1.36. The teeth on the pinion gear are bit shorter than the 32/27 set. I choose to make a 1.36 by swapping out the lower gear set.
http://www.mercruiserparts.com/Show_...%2FII%2FIII%29
Other than that, the upper is the same as the B1x.
Hope that helps.
Dick
Mr Gadgets is offline
Old 01-18-2012 | 12:49 PM
I have a 1.50 sporty so by combining the two drives I would have a 1.36 which means re propping. Not what I wanted to hear. I was hopping a 1.50 b2x was the same as a b1. Do I have that right?
Old 01-18-2012 | 03:29 PM
You're going from a standard drive to an X drive? See bulletin link below,
http://www.boatfix.com/merc/Bullet/00/00_08.pdf
As for you're gears, Hope this helps, Good luck.
1589-865440H50 DRIVESHAFT HOUSING, Complete (Bravo-I 1.36:1 Ratio)(Bravo-II 1.50:1 Ratio)(Bravo-III 1.36:1 Ratio)
http://www.mercruiserparts.com/Show_...nd+Drive+Gears
http://www.mercruiserparts.com/selec...sp?type_id=DRB
lakematdude is offline
Old 01-18-2012 | 07:00 PM
Thanks for all this info. I was ble to get a 32 tooth upper bravo x upper. So that will give me a final ratio of 1.50. According to this I will have to change the gimbal bearing to make it work right? Anything else?
