#6 Prop Shafts repairs
Has anyone repaired #6 prop shafts. I wear out the shaft where the seals make contact and they create a groove and then let water enter the system. I have had this problem before, has anyone ground the shaft and then rechromed them and then ground them down again to specs? These shafts are expensive as we all know and the repair is less than half of the cost of new?
Would you have to start with new shafts for this, or okay to spray or weld the groove back up, machine and then flame spray?
