source for mercruiser hingepin tool and other tools >
Old 02-23-2012 | 06:58 PM
Default fixx
the exhaust bellow is only their to keep from ruining the ujoint bellow with the heat whyle on plane..not needed if your going to block it off and yes their are 2 types of gimbal bearing pullers,,slide 3 jaw slide hammer and a threaded rod style with plates to pull the bearing..still need the instalition tool tho.
FIXX is offline
Old 02-23-2012 | 10:54 PM
Do you heat the pin or the gimbal ring itself? Curious about burning the paint.
cheech is offline
Old 02-24-2012 | 04:56 AM
i stick a jack handle into the gimbal bearing and rotate it part way. then hit it with a punch or long screwdriver to rotate it sideways. then it pulls right out, leaving the cage behind. then clean out inside of cage and pump some grease in to make sure it isn't plugged. put new bearing onto same jack handle and smack cage to rotate it off bearing. then you put new bearing in sideways and rotate it straight. no puller needed. there are 2 slots in bearing cage to remove reinstall bearing. MAKE SURE that you see them before you do this. if prev bearing was installed backwards, the slots face engine and this is not possible. also, when rein stalling bearing, make sure the grease hole in bearing is forward and lined up with grease slot in cage. otherwise it can't be lubed and will have a short life. i don't like pressing cages into and out of the housing. it gets a little bigger with each time done.
dereknkathy is offline
Old 02-24-2012 | 07:22 AM
Originally Posted by jason y
what i was thinkin as well... got my pins out earlier today 5/8s allen on three of course the 4th was stripped out couldnt beat the next size up in it had to beat a snapon extractor in it then heat with propane torch finally gave way... i know snapon tools are high but these screw extractor set about 30 peice has saved my ass enough to justify buying it.. all on stuff i had nothing to do with until it needed repair.. of course ill be installin new pins..
Glad that worked out for you...my 4th one was the one I had to cut. How do the necks that catch the U-Joint bellows on the housing look? If the bellows have been maintained they survive ok...my starboard side was split so I had to replace everything. You should have heard the racket that gimbal bearing made!!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Here are some pics of a home made rig I used to pull the gimbal bearings.
[IMG][/IMG]
[IMG]
[/IMG]
[IMG][/IMG]
[IMG][/IMG]
Take your time...think it through...save big bucks
sprink58 is offline
Old 02-24-2012 | 05:07 PM
scottw's Avatar
Gotta heat the ring around the hinge pin to expand it and breakdown the loctite. Gonna waste the paint either way.
scottw is offline
Old 02-24-2012 | 07:33 PM
The threads aren't in the gimble ring, their in the bellhousing so heating the gimble ring won't heat the threaded area at all. With the drive off you can use a propane torch turned down low and heat the area around the pin inside the bellhousing. It don't need a whole lot to loosen up the loctite.
picklenjim is offline
Old 02-24-2012 | 09:02 PM
heat where the threads goes into where its painted the handheld porpane torch didnt bother the paint def takes some time to get it warm enough though dont use a acetelyne torch as they will blow holes in aluminum super easy..
jason y is offline
Old 02-24-2012 | 09:37 PM
yea i heard the bearing in mine to i knew it was bad where the bellows goes on are good but i had one bolt break off in the housing and stud corroded in half.. so both my transom plates might/are junk
jason y is offline
Old 02-24-2012 | 10:33 PM
well at least you already have the engines out and No 1 transom plates are out there and available.
sprink58 is offline
Old 02-29-2012 | 04:39 AM
Originally Posted by bustedbrick
Bought the hinge pin tool from BAM. Soaked pins from the inside of the gimbal ring with PB Blaster for a few days (one application a day) before trying it. Took a 1/2" breaker bar and a 2ft pipe "extension". They came loose with a loud bang.
i stuck a few allens in them ill have to see if i had mm or ase as i didnt look was just tryin to find one that fit.. yes i already sprayed em down
_________________
download 5000 backlinks
kritiana08 is offline
