Tie Bar adjustment >
Tie Bar adjustment
Tie Bar adjustment
Old 03-08-2012 | 03:22 PM
Default Tie Bar adjustment
I noticed that my drives look like they have been adjusted so there a little toed in. Is this best and if so how much? Where is the best place to measure from? If it makes any difference this is a turn out prop application.
abmotorman is offline
Old 03-08-2012 | 06:00 PM
Mine are toed in about 3/16" this compensates for the outward deflection of the propshaft in relation to the gimbal. The propeller wants to walk the propshaft out. Would be opposite in inward rotation.
SkiDoc is offline
Old 03-08-2012 | 09:41 PM
Makes perfect sense to me. Where do you measure from? The best I can see is by the lower gear housing??? Thanks Andy
Old 03-09-2012 | 05:13 AM
I measure the center of the gimbal housing and the center of the nose cone.
SkiDoc is offline
Old 03-09-2012 | 07:29 AM
Apprieciated!
Old 03-09-2012 | 08:56 AM
fireboatpilot's Avatar
RIPSTA Racing Team
I also run about 1/4" toed in and you have to measure from the tips of the nose cones and the centers of the prop shafts.
fireboatpilot is offline
Old 03-09-2012 | 10:55 AM
alphas, both right hand rot. how should these be set up?
dereknkathy is offline
Old 03-09-2012 | 02:25 PM
OMG, 34 1/2" back 35 1/4" front. I thought from a distance that didn't look right! This should help a bit.
Old 03-10-2012 | 08:23 AM
offshoredrillin's Avatar
so with my props turning in, i want the the front of my drives like this ... towed out \ / or toed in /\
offshoredrillin is offline
Old 03-10-2012 | 08:36 AM
good question. which is in and which is out? i think like a car. the fronts closer is in. or is it the propshafts closer than the nosecones is in? what would one do with 2 same direction drives? toed straight?
