help with drive spacer install >
Old 03-14-2012 | 09:09 PM
Default help with drive spacer install
i am installing a 1 in spacer on my bravo drive can someone give me directions and any help would be appreciated. do i use thread lock, how do i get studs in all the way?
az350psd is offline
Old 03-14-2012 | 11:26 PM
use blue,medium strength locktite,and a stud install/remove tool,pretty easy job.
mike tkach is offline
Old 03-14-2012 | 11:28 PM
Randy Nielsen's Avatar
Yes use threadlocker, You can jam 2 nuts together & tighten the studs that way or there is a stud installer-remover kit that grips the stud with 3 rollers I have used them for years on exhaust studs & they dont mess up the threads. Dont forget the o rings on the drive and the spacer. Randy
Randy Nielsen is offline
Old 03-15-2012 | 01:56 AM
tcelano's Avatar
Go ahead and buy a Snap-on stud extractor. I went through all types of knock-offs when trying to remove some studs with limited clearance. It will be the last one you buy...
tcelano is offline
