removing alpha drive ? >
Old 03-19-2012 | 11:36 AM
Originally Posted by chevytrucks94
Its not the tie bar that's movimg and gouging the housing it is the bolts that come off the top of the drive then the tie bar sits on the drive then there are nuts holding the tie bar to the top of the drive. The nuts are what are catching the housing when the drives are all the way up in trailer mode. If the drives are up perfectly straight its fine but if drive are turnes ar all they hit
Have you looked into if a saddle style tie bar would help your problem?
A.O. Razor is offline
Old 03-19-2012 | 02:20 PM
Ok I see ill have to check into it thanks
chevytrucks94 is offline
Old 03-20-2012 | 09:09 AM
When I took the drive off the water line on the back lower half of the drive was not connected. It has a little white fitting and then a little fitting in the drive it looks like it suppost to snap in to. Are those suppost to b put together?? I assume so but I looked at my other drive and they are not connected either
Old 03-20-2012 | 09:48 AM
Are you talking baout the 1/4 in lines? they are for the speedo hookup. You may have pee tubes (speedo hookup) attached to the transom for your speedo or are you using GPS speedometer
F3504x4ps is offline
Old 03-20-2012 | 11:29 AM
Ha well maybe speedo tubes bc speedo didn't work before. So ill hook them up and see
Old 03-20-2012 | 04:44 PM
Ok gimbal bearing some say put them in with notches facing out so u can spin it and take it out some say don't do it that way. Tell me what u think and y?
Old 03-20-2012 | 04:58 PM
ok, my tie bar is bolted to the back of my trim rams. are you saying your tie bar is bolted to the top cover of the uppers? my drives all way up i have an inch and a half of room between the drive tops and the transom shield where the upper steering pin is. if your tie bar plus brackets is right there, you are gonna run out of room. your tie bar also doesn't have as much leverage to hold drives parallel that far forward. that is only about 6 inches back from transom. i would look for the better setup that attaches to the lowers at the trim rams. in the mean time, all you can do is bump the drives back down a little from the up-stops. you might be able to take a grinder to the tops of the studs and maybe find a lower profile nut. or remove lock washers and spacers. does the bracket bolt to all 4 top cover bolts? if not, move it to the rear 2 top cover bolts.
dereknkathy is offline
Old 03-20-2012 | 05:04 PM
didn't even see second page. i was replying to post 10. on the gimbal bearing, definately put it in so it can be flipped and removed. each time you press that cage into the alum housing the hole gets a little bigger. just watch where the grease hole is in relation to the groove in the cage when putting back that way.
Old 03-20-2012 | 09:50 PM
Ok on the gimbal and yes the tie bar bolts in all 4 places so that was my temporary plan to find a lower nut and cut it down a bit just to prevent as much as possible. Thanks for all thr help
