Bravo or SSM III ?? only options
Those boxes are setup for a verticle mount, that puts the motors way too high in a standard v hull. Also they are 1:1 ratio - that won't work either and the ratios are not easily changed.
For reference, my buddies 38 Cig flatdeck drives are 4" below, ssm IIIA, no boxes, no transom notch. Planes off just fine, no slip whatsover.
My 38 Fountain, with transom notch, ssm iv, propshafts 1.5" below the bottom, is very prop sensitive. With the right props, it lays right over. With the wrong props, grab a snickers before you attempt to get on plane, cuz it'l be a while.
IIIA's have the same size gearing as the V's do, also they are big shaft in the latest design, the first design still implimented a small shaft, and that was soon changed out... I just happen to have a set if you're interested... lol
Just to clarify, x is not measured to the notch, but to the bottom.
Directly below.
Why on earth whould you mount them so the prop sits lower than the current B1 setup? That will not take the full advantage of the drive, slow the boat down cosiderably and so on. You can get 3", 2", 1" and other spacers for the IIIs. They are surface drives and are supposed to be run as such, so are the cleaver props that go with it now a days. Don't forget that prop technology has come a long way since the IIIs came on the market. I would not go below 24.25 personally and then space from there, IF EVEN NEEDED! 5 blades, 6 blades, 20-21* rake ect. Lots of options available in terms of props. If you want to go fast. go high.
KVOGT isn't talking from his a$$. He has a 107mph 38 Flatdeck with Arnesons that he built, his brother has a 38 Flatdeck with SSM V's and boxes, that he rigged from TRS, his good friend Tom had a 39 Chris Craft Stinger (same hull as the Excalibur Hawk) that had SSM IV's on boxes, which i believe ran into the 90's. Not too mention a 41 Apache they are re-rigging.
I can tell you my buddies 38 Flatdeck Cig, with IIIA's mounted 4" below the bottom, while does plane well, has a slip of over 22%, with 4 blade 17" diameter props. Maybe some 10k dollar Herrings would help lower that, but 10k dollar props ain't in the budget. And not sure if they are in LIL Red's budget either.
With 600-700HP per side, in that Excalibur Hawk, Mounting the drives even with the running surface is probably gonna = a poorly planing boat, ineffecient cruising, and the engines mounted very high. He'll need those blower scoops, even without a blower. My old excalibur hawk had TRS, and the drives were in the basement. Standard 3" flame arrestors barely cleared the stock hatch. If I remember correctly, the factory TRS propshafts on mine were like 7" below the bottom!! Running 4 blade hydromotive props on that setup I had about 15% prop slip.
Going up in X dimension doesn't always mean going faster. My buddy Bob has a 2006 42 Fountain, stock 525's, and XR drives. Boat was never that great at planing off, even with 5 blade P5X props. Added 2" spacers, actually gained a couple mph, planed better, and cruised better. Same exact deal with my friend Mark's 38 Flatdeck cig with Konrad's. He ended up running spacers because the boat just ran better with them, and thats with 5 blades too.
My overall opinion is install the III's, keep the propshafts about 3.5-4" below, run a basic 4 blade SSM prop that wont cost more than the drives themselves, nor will they tear them up like a 6 blade running at the surface (III's do have their HP limits). Enjoy a boat that will plane off with a full tank of fuel and a boat load of hot chicks. Also, enjoy a boat that won't blow the props out in heavy seas. Getting on plane with III's mounted at the running surface in 5ft swells will be real fun. I can tell you my 38 Straight bottom Fountain with the shafts 1.5" below, even with the right props, has a tough time getting on plane in heavy seas. However, when up and running, my prop slip is only 10%. Fountain factory rigged mine, but its a totally different animal than yours. Smaller, lighter, pad bottom, etc. If going fast is the ultimate goal, get a different hull.
If you wanna bring the drives way up, sell the III"s, get a IV or V. That was a drive that was INTENDED to be a surface drive. Look at the SKEG on a III, then look at the Skeg on a IV or V. There was a reason the skeg is so large on the IV and V. The III wasnt introduced as a surface drive. The entire reason mercruiser introduced the SSM IV, was in answer to Howard Arneson's drives in the 80's, since the Arneson equipped boats were doing so well and beating the SSM III equipped boats.
