Bravo or SSM III ?? only options
#31
For a non-step boat, having the prop a bit low gives the drive(s) leverage to carry the nose which lowers total drag more than the added drag of the lower mounted drive(s). So you could end up with better planing, midrange and top speed.
#32
agreed... a small sacrifice to make in the larger picture of driveability... and yes Mild Thunder, the III, as it was intended by Mercury, was to be run below bottom, not above like a IV or V...
the way I rig these boats is usually in the area of 2.5" to 3" below if the engine location will allow for the high mounting... seems to give the best of all performance, planing ability good midrange and topend performance...
#36
#38
III's and IV's are rock solid up to 600 something. People push them much harder, and they last a while, but I have seen gears start to go after extended usage at 850 hp on a SSMIII.
#39
