Wilson Lowers
i tried to work mine with sand paper and lots of love thinking i could do "blue printing" and ran hard 3-4 times with zero results... i finally sent my imco lowers to craig at wilson custom and he literally made love to these things, gained me 3 mph without pushing the boat, made my boat handle 10x better, and says if i send him the props there is more to come............ my drives look nothing like stock imcos anymore..... WCM are lower genuises, worth every penny
Hi TWIN-SPINS,
My preferred weapon of choice for roughing out is a bosch electric dye grinder with a coarse aluminium burr, the finer detail work is done with a small air dye grinder with smoother burrs. The straight lines are achieved with a course body file followed by a second cut half round file, i then use a rubbing block for the outer radiuses and then a broom stale wrapped in production paper for the internal corners finished of with scotch brite. All of the above processes require good hand eye co-ordination as Craig has pointed out Wilson Custom Marine has been doing this for many years and have great crudentials in this area. I like to make and modify as many components for my own boats as possible and i don't mind too much if it doesn't work out first time i can always weld them up and try a new shape, not something i would reccomend unless you have the time and facilities.
Peter
Peter
This thread is very interesting & look forward to more posts....... especially the pics!!!
Sound to me like WCM knows what they're doing.
Would love to see them post a few pics of the drives they are working on?
Thanks, Tim Bostic
Hoss Marine Props
p.s. Thanks Peter for sharing your stuff.
Thanks, Tim Bostic
Hoss Marine Props
The thinking behind re-shaping the rear of the lower units is to try and reduce the turbulent waterflow to the props ideally i would like to do this over a much longer distance to make it a much more gradual transition but i would need to strip the drives and check wall thicknesses before removing any more material. I have had excellent results re-shaping the Volvo DPR lowers on our diesel boat which used to suffer quite bad propeller erosion. To me modyfing and testing new ideas is a really fun part of boating sometimes it works sometimes it doesn't
All the best
Peter
