bravo 1
Old 04-21-2012 | 11:20 AM
Default bravo 1
i have two bravo one drives on my boat, one goes in and out of gear smooth and quiet and the other one makes a clunk noise when i put it in forward and reverse. i was told it was just the difference in the way it was machined. is this true?
mrk63 is offline
Old 04-21-2012 | 04:20 PM
Welcome to the boards.
It is usually play in the cables. It can be adjust so not so abrupt an engagement. Is that motor idling higher than the other ? That can do it to.
GTOFFSHORE is offline
Old 04-21-2012 | 11:11 PM
Default fixx
welcome to the world of reverse rotation..one drive when you put it in gear it push's the upper grars down,the other counter rotating will push the upper gears up into the cap..so they will sound differant.
FIXX is offline
Old 04-22-2012 | 07:31 AM
seafordguy's Avatar
Also - be sure to check that your prop is tightened down to the appropriate amount. I doubt that is it, but just a thought.
seafordguy is offline
