Alpha one first gen counter rotaion identification? >
Old 05-03-2012 | 05:32 AM
Originally Posted by MOP
They were Ok in a dual setup, the big issue is they will not hold the same amount of power that a standard rotation does.
is that also the case with the SEI CR drive? thanks.
dereknkathy is offline
Old 05-03-2012 | 11:37 AM
Good question?!?!?!? Curious about that. They are both same warranty and same HP rating, so wonder what the strength difference might be on the SEI if anything.
Brian
befu is offline
Old 02-26-2022 | 12:51 PM
Originally Posted by picklenjim
You can still get any part you would need for that drive from Mercury. The lower unit is the only thing that makes it CR and you can still get those complete. If it broke I would buy a SEI before repairing it with merc parts. You can get a complete SEI with 3 year warranty for $1500. I would say that one if it works is worth about $5-600. Nothing special about those and wouldn't be that hard to find another. If you are thinking of buying it you better find out what gear ratio it is.
Picklejim, are you positive the counter rotating is done in the lower?
Rich Abt is offline
