Trim fluid leaking >
Trim fluid leaking
Trim fluid leaking
Old 05-11-2012 | 03:39 PM
Default Trim fluid leaking
Installed new cylinders and external lines to block. Rebuilt pump connected to lines from pump to block. TR sterndrive, Fluid running out inside transom.
Possible line to block leaking??? Hard to replace?
Thanks, Bill
kawmagnum is offline
Old 05-12-2012 | 08:32 AM
you need a little mirror and a flashlight and play go fish. i think block unbolts from outside and pull lines partway through to unbolt. if you detach and pull out, tie a string to end to pull it or new one back in...
dereknkathy is offline
Old 05-14-2012 | 10:43 PM
Default Thanks for the reply
You are correct-2 nuts and pry block out. Only problem- 1/2 of the block was disintegrated. Got lines cleaned up, and found some new "old stocks" are still available. Next....
Old 05-15-2012 | 10:42 AM
coinicendence... possibly.
we are doing the same job this week. ordered the block and hoses. im nervous about fishing the lines. it seems pretty tight in there.
1MOSES1 is offline
Old 05-15-2012 | 11:56 AM
Duck soup.
picklenjim is offline
Old 05-19-2012 | 08:31 AM
we ended up replacing the block and both hoses...
unbolted the block from the outside. cut each line since we werent re-using anything. then fished steel wire up each hose until it came out the other end. once the wire was fished, took out the old line and put the new one in using the same wire. took a little fanagling but they went back in.
the hardest part is formula zip tied the old hoses down. i had to take foot long shears to reach down and cut the ties. also the mercathode system on the bottom of the block manifold is a nightmare. it took me an hour to peel the old caulk out to access the wires.
1MOSES1 is offline
