Bravo derivative to handle 750HP >
Old 12-01-2012 | 04:18 PM
later's Avatar
Rik im curious have you done any bravo conversions on 42 Fountain stepped hull and what was the results?
later
later is offline
Old 12-01-2012 | 11:17 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
later
The 42' Fountains run very well with Arnesons. What power do you have?
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 12-02-2012 | 07:36 AM
Originally Posted by Rik
Start with them inboard and then try outboard. Just swap drives side to side...
Ok will do. What ride difference would you expect to look for with them running out versus turning in ?
laszlo01 is offline
Old 12-02-2012 | 11:41 AM
later's Avatar
500hp right now the boat run right at 80 what kind of increase would i be looking at. and does the transmission fit in the stand off boxes or the inside?
later
later is offline
Old 12-02-2012 | 04:04 PM
Your best bet is to buy some wet 6's for 35k or go with the arnesons for 45k. Both will be bulletproof for your application,
Lexanlarry is offline
Old 12-16-2012 | 10:41 PM
I must have missed the press release where everyone else was sponsoring the drives that were breaking and bleeding everyone of their "left over" $$
there are some used Arneson setups for sell in oso classifieds. I do not know if they are complete kits or condition of them. But never hurts to check into.
rtc74 is offline
Old 12-17-2012 | 01:24 PM
THEJOKER's Avatar
Originally Posted by RBeyer
I had a BMax that was perfect for 5 years behind 720 hp. Lost about 2mph but worth not being on the trailer.
Our B-Max on a SVL Big engine was faster. Never broke and even won 1st overall on Saturday in St Pete 2001.
THEJOKER is offline
Old 12-18-2012 | 09:43 AM
Did you do anything special to the lowers? I thought I heard somewhere they had come out with a poker run version lower which looked more hydrodynamic.
ThisIsLivin is offline
Old 04-02-2013 | 05:22 PM
Their new lowers are more hydrodynamic for sure. John spends hours hand shaping each one now. Definitely a work of art.
QWKRN U is offline
Old 04-03-2013 | 02:15 AM
Default gears
too bad someone just want cut some bravo gears out of a stronger metal. what would happen if a person could buy gears for their imco scx upper and sc lower with gears made from Titanium, inconel or even Tungsten carbide? i know they would be very pricey but strong as heck, the last very$. there are many other very strong metals that would fit the bill. i would pay 3 times (or more) $ for hard gears! if the gears are the major weak point, build them stronger. maybe im just missing something and should buy the scx lower thats shaped like a sperm whales head! someone please set me straight
La/stryker is offline
