Time to remove drives, do not have lock key >
Old 09-17-2012 | 05:17 PM
I know this is not the best thread to start, but I don't know what else to do.
I want to remove my drives this fall for winter refresh and bilge paint.
My drives have locks on them, the type that have a cylinder that spins around the lock. A standard wheel lock removal tool will not work. Cutting them off without doing cosmetic damage seems impossible.
I was once told there is a removal tool that has pins that you hammer between the outside and inside of the lock, does anyone have a link to this?
Mods can remove this thread after I get an answer if you wish
lock type
http://www.amazon.com/McGard-74018-M.../dp/B0016H3Q7A
4bus is offline
Old 09-17-2012 | 07:06 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Removed several of those with zero problems, nor a scratch. I just use a dremel with a cut off wheel and made 2 cuts thru the sleeve as deep as possible, then just split the sleeve off with a screw driver. Then just drive a socket over the nut/lock and unscrew. A few minutes per drive. Those locks are so easy to remove they aren't even a deterrent IMO. However I have them on my drives along with pics showing so. Figure if nothing else, it'll show my ins I had taken some extra measures.
US1 Fountain is offline
Old 09-17-2012 | 07:09 PM
I bought a boat with them. Took a picture of them and bought some keys from the lock manufacture.
offshorexcursion is offline
Old 09-17-2012 | 08:16 PM
nitrousnolan's Avatar
There is a way simple and quicker way to remove these. Happens all the time on the repo boats. I think my record removal for a set of drives was just over 2 min. Call me
nitrousnolan is offline
Old 09-18-2012 | 11:39 PM
BUP
Whats your phone # as we get the same problem all the time. Owners either bought the boat without the chuck or has lost it. Thanks
BUP is offline
Old 09-19-2012 | 11:45 AM
Snap-on makes a tool for this and locking lugs for cars. It looks like a socket but has tapered reverse threads on the inside and as you turn it bites into the lock until the lock gives way and rotates with the socket.
1987pachanga22 is offline
Old 09-19-2012 | 12:41 PM
You can carefully walk them loose with an air chisel.
thirdchildhood is offline
Old 09-19-2012 | 01:13 PM
eddie's Avatar
I took some off a boat I purchased the same way. About 30 minutes for the six locks.
eddie is offline
Old 09-19-2012 | 02:06 PM
Those sockets will not work on drive locks, they have a collar on the outside that spins free, the lock is inside this collar.
McGaurd is sending me a key, took the advice above. I need to send them close up pics of the lock internals, pic of the boat Vin and copy of the title.
4bus is offline
