trs driveshaft/bell housing question >
Old 12-16-2012 | 11:42 PM
Mr Gadgets's Avatar
Charter Member #601
Good info, Jim, thanks for adding it..
I am not familar with this older stuff, so it is always helpful to have someone that has seen it!
Thanks!
Dick
Mr Gadgets is offline
Old 12-17-2012 | 01:21 AM
To tell you the truth this is the first time I've ever seen or known there was a set up like that for the Alpha/Bravo. They have a very similar looking setup for the staggered engine TRS with the difference being the borg-warner trans bolted to the bellhousing instead of the extension support used with the Alpha/Bravo. I checked the part number of the bellhousing and it's the same one used on the old 330's TRS's w/borg-warners. Notice it's also equipped with the provision for a top mount starter if desired.
picklenjim is offline
