Bravo XR to IMCO SCX Conversion >
Old 03-06-2013 | 11:01 AM
  #41
Originally Posted by Quinlan
What oil are you guys using in the SCXs? I just ordered mine
Also the Torco will come in the crate with your drives... It did for me at least.
Congrats on ur purchase.
Pat
Spicy is offline
Old 03-06-2013 | 11:06 AM
  #42
Torco RTF
KWright is offline
Old 03-06-2013 | 04:45 PM
  #43
Quinlan's Avatar
Pat
Cool and Thanks, Im stoked, smaller pully and more HP this yr!! WaHooo
Quinlan is offline
Old 03-06-2013 | 05:43 PM
  #44
That's what I need, to release a PO to Whipple for a set!!!
Spicy is offline
Old 03-18-2013 | 03:01 PM
  #45
Quinlan's Avatar
Mine are on the Road!!
Quinlan is offline
Old 03-18-2013 | 05:47 PM
  #46
GAZ
Originally Posted by 1 MAIDEN AMERICA
What did you notice was different? I use the Torco. It shifts into gear perfect every time. Occasionally it'll clunk coming out of gear but I think that's caused by the engine trying to keep that 17" prop spinning at idle.
I pulled the pinion to peek and the gears look new after 50ish hours.
Great ! I like the sound of that, Hope mine look like new after 50 hrs.
GAZ is offline
Old 03-21-2013 | 05:58 PM
  #47
TRL505's Avatar
Mine did same thing....until I switched to Bmax oil. Much smoother overall shifting in and out of gear. If your having good luck with the Torco..then no reason to switch.
TRL505 is offline
Old 03-24-2013 | 09:35 AM
  #48
MarkDonzi's Avatar
OK, the drives are hung on the boat and my steering rams which come off my extension box do not align properly with the attachment points on the SCX upper.
My previous setup had a stainless steel plate made by latham that bolted on the top of the XR Drive. We are going to use that plate as a template and make a new plate to go on the top of the SCX drive then everything else will be the same, tie bar etc.
Anybody set theirs up like this before?
MarkDonzi is offline
Old 03-24-2013 | 10:07 AM
  #49
Originally Posted by KWright
Torco RTF
Does anyone use royal purple?
JMPH is offline
Old 03-24-2013 | 10:38 AM
  #50
Here is what mine looks like. You are lucky if you can use you old tie bar. I had to get a new one for the scx. It is much thicker than the xr/bravo one.
Attached Thumbnails Bravo XR to IMCO SCX Conversion-2_09_07_12_12_17_19_8539341.jpeg
indywhsle is offline
