Filling SSM drives
What do you guys like to use, I don`t feel like pumping 5 gal. manually.
I was looking at these:
http://compare.ebay.com/like/1507107...Types&var=sbar
http://www.ebay.com/itm/JOHNSON-PUMP...7998%26ps%3D54
The Johnson comes with more stuff but its plastic..
I used one of the Jabsco oil draining pumps that is mounted on a 5gal. pail, that is used for "sucking" oil out of a marine pan with either a long tube or attached to a stock Mercury dip stick tube.
I used the suction side of the pump to suck fluid from my fill container and the "pressure" port to fill the drive. I made a cone shaped adaptor to wedge into the bottom fill port of the drive, filled the drive until the fluid came out the upper side port, put the top plug back in and continued to fill until there was just the right amt. in the interior overflow bottle. You can fill the drive in a fraction of the time with no air pockets this way. I sold my boat and have the whole system for sale. Let me know if you are interested, I can send pictures.
Gary
612-247-7082
Gary
612-247-7082
I should have known Gary would have something..
Shoot me a price and also on that magic gear oil you got, I checked into it and it was $$$$$ but since you`re so awesome you`ll let me have it cheap right???
dan,i have a 5 gallon deal i bought several years ago that pressurizes and pumps the lube into the drive,call me tomorrow and il text you a picture and the name brand.i think it was about 150 bucks,but it is worth it,no spill or mess.
Hey Dan, if money is tight maybe you can use your penis pump?
I personally use a jabsco drill pump. Cordless drill, one end of hose into bucket of lube, other end clamped to the fill fitting that screws into the drive. Takes about a minute to fill the drive with 2.5 gallons or so. I keep the drilling going somewhat slow so I don't blow $hit out. I also use this nifty little pump to suck the engine oil from the oil pan. Not as nice as those jabsco 150 dollar units, but cheap.
http://www.ebay.com/itm/JABSCO-DRILL...item3f2086228b
Or your way
http://www.ebay.com/itm/POWER-PUMP-P...item35c38edf7a
Or your way
Or your way
Or your way
