upgrate alpha 1 to bravo xr. transom. >
Old 02-14-2013 | 11:18 AM
Default upgrate alpha 1 to bravo xr. transom.
Anybody done this change, are the two transom cut outs very different or maybe the same size, any hits guys ?
The existing set up is worn out, and Ive been given a great deal on the bravo set up which is the reason. Power is
bluewater magnum small block. I know ill need a water pump its the transom thats the concern. Thanks.
bernie is offline
Old 02-14-2013 | 11:35 AM
Cutout is the same. May need to drill 2 holes if its gen 1 alpha. Other than that very easy to bolt in place. Will also need a bravo coupler I believe. But transom is easiest part of swap.
Crude Intentions is offline
Old 02-15-2013 | 05:29 AM
thanks ICU thats good news.
bernie is offline
Old 02-15-2013 | 05:37 AM
Does that also mean that the bravo input shaft/ motor line up will be the same as the old alpha?
bernie is offline
Too Stroked's Avatar
Remember though that a straight Alpha to Bravo swap will gain you reliability, but lose you speed due to the higher drag of the Bravo gear case.
Too Stroked is offline
Old 02-15-2013 | 11:47 AM
Too Stroked , Is that drag due to the shape of the gear case in the water, or greater friction inside the gears / case itself?
bernie is offline
Old 02-15-2013 | 12:01 PM
It's due to a larger drive in general and bigger internals requiring more power to turn I think. Whenever you pull the motor you always re align with alignment tool even if you don't swap. So albeit minimal adjustments, you will still need to verify alignment.
Old 02-15-2013 | 02:19 PM
Greater hydrodynamic drag.
Old 02-16-2013 | 04:06 AM
thanks guys.
bernie is offline
Old 02-21-2013 | 12:08 AM
This is how it gets done.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Pretty simple actually. Take your time and make sure you drill the two upper holes at the proper angle so the studs/bolts go thru the transom as they should.
sprink58 is offline
