-   -   Bypass trim limit senders? (https://www.offshoreonly.com/forums/drives-lower-units/292423-bypass-trim-limit-senders.html)
Unlimited jd 04-01-2023 07:06 PM
3 wire plugs in to smartcraft, and the ecm limits trim to a percentage. A 2 wire plugs directly inline with the blue wire from the trim switch and opens at the set level.
atomicd 04-02-2023 09:47 PM
If I jump inline on the blue wire, that will do the trick. What about trailering, how do I raise the drive beyond the limit to ensure the engine doesn't hit the ground or is that necessary once the limit is set?
SB 04-03-2023 08:29 AM
At the switch at the helm use the wire from the trailer up for you’re ‘up.’
better words: make your ‘up’ wire the actual trailer up wire.
I believe it’s the purple / white wire.
Remember, regular up is blue/white and down is green/white.
