x-dimension
Old 03-20-2013 | 02:43 PM
Default x-dimension
I have a 1981 23.5 eliminator daytona that i have completely redone. it org. came with a trs drive. i since have filled the transom and i am going to be installing a bravo 1. I know from the factory the pre 95 daytona's had a low x-dimension so here is my question. Does anyone know what x-dimension i should use to help this boat perform as well as possible?
dgray75 is offline
Old 03-29-2013 | 10:33 AM
Unhappy
Any help?
dgray75 is offline
Old 04-01-2013 | 08:15 AM
Have you tried calling eliminator?, If they can't help I would call Teague next.
pstorti is offline
Old 04-01-2013 | 11:33 AM
Unhappy
Ya, I talked to them. They gave me the x on the new 22' boats
they are rigging now.
dgray75 is offline
Old 04-02-2013 | 07:37 AM
Maybe you can find a similar boat that is for sale and ask the owner what his x is?
pstorti is offline
Old 12-22-2013 | 05:49 PM
Have you completed your set up? I put a bravo 1 on a 1985 23 daytona, put it as high as I could which gave me a 2.5" xdimension. 468 blower motor it ran 95 with a 5 blade signature hill prop, still need to test more. Lots of slip and blowout with 4 blade bravos. 3-4" xdim might be better
Neil_98 is offline
Old 12-22-2013 | 05:58 PM
There is no possible way to get a 2.5" x dimension. But at 19.5" a bravo prop shaft is 2.5" below the running surface.
Unlimited jd is offline
Old 12-22-2013 | 06:54 PM
Yes, I was referring to prop shaft measurement below sponsons
Neil_98 is offline
